data export in v4.3
Hello together,
due to a reconfiguration of my computer, I had to reinstall Comsol, which only is now available for me as v4.3. The calculations I did already are done in v3.5a. I am able to open the files with the new version, but I am not able to export the results.
Is it possible at all, to export my old data in the new version?
Karsten
1 Reply Last Post 9 nov 2012, 14:21 GMT-5
Posted: 1 decade ago 9 nov 2012, 14:21 GMT-5
probably not, you must then rerun/solve it again
But you can visualise many things, if you look carefully you will have a 3.5 tagged mesh and solver study "data set" but if you rerun you will get a new Data set, and a 2nd mesh node
Anyhow my experience is that it's nice to open old 3.5 files, but I always remake the fresh in v4, at best I can copy some of the formulas from the old version, or save and reload hte geometry. But for the rest so many things have changes, variables names, logic ... that s far "my way" is to redo them. It helps you learn the "new" way, and I notice I can often improve the model structure
Hi probably not, you must then rerun/solve it again But you can visualise many things, if you look carefully you will have a 3.5 tagged mesh and solver study "data set" but if you rerun you will get a new Data set, and a 2nd mesh node Anyhow my experience is that it's nice to open old 3.5 files, but I always remake the fresh in v4, at best I can copy some of the formulas from the old version, or save and reload hte geometry. But for the rest so many things have changes, variables names, logic ... that s far "my way" is to redo them. It helps you learn the "new" way, and I notice I can often improve the model structure -- Good luck Ivar
