Global parameters vs. Model/Definitions/Variables
It seems that the geometry can only be defined by global parameters while the rest of the modeling can also use variables.
Is there a way to access the model variables in the geometry such as mod1.Definitions.Params1.xab where xab is a variable that belong to Params1 in variables?
Thanks in advance.
Kamil
3 Replies Last Post 14 nov 2012, 08:44 CET
Posted: 1 decade ago 13 nov 2012, 18:29 CET
Hello, Kamil,
I see it this way: it seems that Geometry only accepts Parameters (they are only available as Global Definitions), not Variables (may they be Global or Model-scope). You can see that neither a Global Variable is accepted in the Geometry.
Jesus.
Hello, Kamil, I see it this way: it seems that Geometry only accepts Parameters (they are only available as Global Definitions), not Variables (may they be Global or Model-scope). You can see that neither a Global Variable is accepted in the Geometry. Jesus.
Posted: 1 decade ago 13 nov 2012, 20:43 CET
but parameters can be changed with the "external Parametric sweep node" and then you adapt your geoemtry and can solve for different Parameter values
Hi but parameters can be changed with the "external Parametric sweep node" and then you adapt your geoemtry and can solve for different Parameter values -- Good luck Ivar
Andrea Ferrario COMSOL Employee
Posted: 1 decade ago 14 nov 2012, 08:44 CET
Hello Kamil,
Jesus is right: only "model parameters" (the ones in the Parameters node) can be used in the construction of the geometry. The reason is that those parameters have always a fixed value each time you solve (or at each step of a sweep). "Variables", instead, can be defined using almost anything: you can have a variable that depends on the solution and that cannot be used to construct the geometry directly.
If you need to solve problems such as "find the right dimension so that a certain condition is met", you need to follow Ivar's advice and perform a parametric sweep, or use optimization (if you have the required module).
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Hello Kamil, Jesus is right: only "model parameters" (the ones in the Parameters node) can be used in the construction of the geometry. The reason is that those parameters have always a fixed value each time you solve (or at each step of a sweep). "Variables", instead, can be defined using almost anything: you can have a variable that depends on the solution and that cannot be used to construct the geometry directly. If you need to solve problems such as "find the right dimension so that a certain condition is met", you need to follow Ivar's advice and perform a parametric sweep, or use optimization (if you have the required module). -- Andrea Ferrario Electromagnetics Group COMSOL AB
