Hello Timothy Fawcett
Jeff Hiller
COMSOL Employee
8 years ago
11 lug 2016, 12:06 GMT-4
Hello Tim,
The reason for this is likely that you specified initial conditions that are inconsistent with the boundary conditions you picked. At t=0, this inconsistency causes under-/over-shoot in the first element next to the boundary (assuming that you are using quadratic elements, which is the default for most physics), see attached picture showing what I mean in 1D.
The solution consists in specifying consistent conditions. If for instance you are trying to model how a system responds to a sudden ramp-up of a field on a boundary, then use a function that starts at the initial value and ramps up to the final value in your BC. Instantaneous changes in value are frequently unphysical anyways.
I hope this helps future readers of this thread.
PS: This is closely related to the third possible cause for negative concentrations discussed at this link:
www.comsol.com/support/knowledgebase/952/
Hello Tim,
PS: This is closely related to the third possible cause for negative concentrations discussed at this link: https://www.comsol.com/support/knowledgebase/952/
