try/catch in matlab for COMSOL
I am doing a parametric sweep in COMSOL with the geometry. The problem is, it is a large parameter space and a few combinations which would be unreasonable to check give an error. It is a stationary solver and what I need is something in COMSOL matlab code to tell me if there is inverted geometry or too many iterations such that I can skip that set of parametric values. I get the error:
For example, can I have COMSOL output the iterations as it solves such that if it hits a certain amount, I can quickly tell if I need to skip that set of parameters. This is inside a huge FOR loop as I need to sweep over a very large parametric space.
"??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Failed to
find a solution for the initial parameter
(rethrown as
com.comsol.util.exceptions.FlException)
(rethrown as
The following feature has encountered a problem
Failed to find a solution for the initial
parameter
Maximum number of Newton iterations reached
Returned solution is not converged
- Feature: Stationary Solver 1 (sol1/s1)
- Error: Failed to find a solution for the
initial parameter."
2 Replies Last Post 1 feb 2013, 20:23 GMT-5
Hello Alexander Warning
Pierre-Yves Prodhomme
Posted: 1 decade ago 1 feb 2013, 05:35 GMT-5
I don't know if you got an answer to your post.
I am stuck with a similar problem.
With a stationnary solver I would like COMSOL to calculate all the parameters even when he didn't converge for one particular parameter. For the moment when COMSOL is not able to converge for a parameter it just stops as you said. This is bothering. I am sure there is a solution but I cannot find it...
Any help would be appreciated.
Thanks in advance.
I don't know if you got an answer to your post. I am stuck with a similar problem. With a stationnary solver I would like COMSOL to calculate all the parameters even when he didn't converge for one particular parameter. For the moment when COMSOL is not able to converge for a parameter it just stops as you said. This is bothering. I am sure there is a solution but I cannot find it... Any help would be appreciated. Thanks in advance.
Posted: 1 decade ago 1 feb 2013, 20:23 GMT-5
Check for "stop condition" in the help. It's explained pretty well there.
