Transient Hot Wire Method
Hi Everyone!
I'm new on COMSOL so I don't know too much yet. I need to simulate the transient hot wire method, I don't know how to start with, and I cannot find any example. Could somebody help me with that, or where could I find some model example?
Thank you very much
Best
Yolanda
2 Replies Last Post 19 nov 2012, 07:00 GMT-5
Posted: 1 decade ago 16 nov 2012, 15:12 GMT-5
Which physics do you need ? That should be the first question: which depednent variable is to call the driver and which others are the one you want to measure/test.
probably some Joule heating from a current or a potential, and xome cooling of the Joule effect by some air convection, with or withou forced flow.
Looks like conjugated heat flow or a mix of joule heating and Heat transfer in fluids and solid.
But this is just a guess ...
Try te run a few examples of the model library, start simple one physics, i.e. joule heating, and then HT in solid, in fluids, then combine.
Hi Which physics do you need ? That should be the first question: which depednent variable is to call the driver and which others are the one you want to measure/test. probably some Joule heating from a current or a potential, and xome cooling of the Joule effect by some air convection, with or withou forced flow. Looks like conjugated heat flow or a mix of joule heating and Heat transfer in fluids and solid. But this is just a guess ... Try te run a few examples of the model library, start simple one physics, i.e. joule heating, and then HT in solid, in fluids, then combine. -- Good luck Ivar
Posted: 1 decade ago 19 nov 2012, 07:00 GMT-5
Thank you Ivar,
I'm going to try that and see if it works.
Best regards
Yolanda
Thank you Ivar, I'm going to try that and see if it works. Best regards Yolanda
