difference in results when the duration of the model was changed
Posted 16 nov 2012, 12:33 GMT-5 Computational Fluid Dynamics (CFD), Results & Visualization, Studies & Solvers Version 4.3a 1 Reply
Hi!
I ran the same model for a longer time (Rotating Machinery, Laminar Flow module) and the resulting velocity and pressure are different. Which one should I trust? Why does this happen?
For the 2 s duration model at 2 s:
Volume velocity range: 0 to 0.5801 m/s
Volume pressure range: -99.33 to 365.86 Pa
For the 5 s duration model at 2 s:
Volume velocity range: 0 to 0.5364 m/s
Volume pressure range: -114.64 to 294.14 Pa
The mesh is the same, as well as the time step and everything else in the model. The only difference was the total duration of the model.
Thank you,
Sylvana
Thank you,
Sylvana
1 Reply Last Post 16 nov 2012, 15:22 GMT-5
