Electrostatically actuated cantilever beam
I am conducting electrostatic pull in voltage study on cantilever beam, I am getting this error "Failed to find a solution for the initial parameter. Maximum number of Newton iterations reached. Returned solution is not converged. Not all parameter steps returned." in stationary solver 1. I have tried reducing Mesh size but it is not working.
3 Replies Last Post 31 ott 2023, 08:42 GMT-4
Posted: 10 months ago 30 ott 2023, 10:25 GMT-4
Updated: 10 months ago 30 ott 2023, 10:24 GMT-4
Hello Meet,
It's hard to say without seeing your mph file, but if I was to venture a guess, it would be that the first voltage applied is too large. Try ramping up the voltage more progressively. If that's not the issue, consider uploading your mph file.
Jeff Hiller
Hello Meet, It's hard to say without seeing your mph file, but if I was to venture a guess, it would be that the first voltage applied is too large. Try ramping up the voltage more progressively. If that's not the issue, consider uploading your mph file. Best, Jeff
Posted: 10 months ago 31 ott 2023, 05:56 GMT-4
I am doing pull in voltage study using stationary study using auxiliary sweep for Zset. in stationary solver i have Fully coupled linear solver as Direct, that is where I am getting the error "Failed to find a solution for the initial parameter. Maximum number of Newton iterations reached. Returned solution is not converged. Not all parameter steps returned. "
Posted: 10 months ago 31 ott 2023, 08:42 GMT-4
Updated: 10 months ago 31 ott 2023, 08:42 GMT-4
Can you please upload your mph file?
Jeff Hiller
Can you please upload your mph file? Jeff
