Coordinate systems: From 2D axial symmetry to 3D
Hey,
I encountered a problem when modeling heating of a 3D copper cylinder in 2D axial symmetry. I tried to do an Arrow line plot in 3D over "total heat flux" but the arrows appearing are not physically correct, since it by default plots:
{x,y,z}={ht.tfluxr, ht.tfluxphi, ht.tfluxz}. Meaning that what I plot is radial component of heat flux in x. How can I go around this problem without making a 3D model? I tried using {x,y,z}={ht.tfluxx, ht.tfluxy, ht.tfluxz} as if I did it in 3D but it does not work.
Petter
cylindrical coordinates cartesian
7 Replies Last Post 23 nov 2012, 07:44 GMT-5
Posted: 1 decade ago 22 nov 2012, 15:56 GMT-5
sometimes COMSOL proposes plot settings that do not correspond to the type of geoemtry you have, then you must open the corresponding plot node and change the variable names, typically switch the x,y,z,r or whatever vector component suffixes
This is a postprocessing command, and no need to resolve
Hi sometimes COMSOL proposes plot settings that do not correspond to the type of geoemtry you have, then you must open the corresponding plot node and change the variable names, typically switch the x,y,z,r or whatever vector component suffixes This is a postprocessing command, and no need to resolve -- Good luck Ivar
Posted: 1 decade ago 22 nov 2012, 17:37 GMT-5
Thanks for your quick response Ivar! I must still be missing something since I do not get it to work even with your advise. When using 2D-axial {x,y} does not seem to exist. The only define coordinates in the model is {r,z}, not even {phi} seems to exist. However, the proposal when plotting total heat flux for the 3D-model generated by the symmetry is:
x-component: ht.tfluxr
y-component: ht.tfluxphi
z-component: ht.tfluxz
I can't change it to:
x-component: ht.tfluxx
y-component: ht.tfluxy
Since comsol gives the message:
"Cannot evaluate expression.
Failed to evaluate variable.
- Variable: ht.tfuxx
- Geometry: 1
etc..."
Where am I thinking wrong? I also tried to plot {nx,ny,nz} but i get the same error message for nx.
Any idea?
Petter
Thanks for your quick response Ivar! I must still be missing something since I do not get it to work even with your advise. When using 2D-axial {x,y} does not seem to exist. The only define coordinates in the model is {r,z}, not even {phi} seems to exist. However, the proposal when plotting total heat flux for the 3D-model generated by the symmetry is: x-component: ht.tfluxr y-component: ht.tfluxphi z-component: ht.tfluxz I can't change it to: x-component: ht.tfluxx y-component: ht.tfluxy z-component: ht.tfluxz Since comsol gives the message: "Cannot evaluate expression. Failed to evaluate variable. - Variable: ht.tfuxx - Geometry: 1 etc..." Where am I thinking wrong? I also tried to plot {nx,ny,nz} but i get the same error message for nx. Any idea? -- Thanks Petter
Posted: 1 decade ago 23 nov 2012, 01:53 GMT-5
what about rereading some of the docs user manual on 2D-axi (I preconise to index the PDF and to do searches thereon). You will then see that 2D uses (x-y) as (horizontal respectively vertical 2D) coordinates, but in 2D-axi these are renamed (r-z) that is "why" you need to do the mapping x=>r y=>z but once you have got this trick its easy ;)
Hi what about rereading some of the docs user manual on 2D-axi (I preconise to index the PDF and to do searches thereon). You will then see that 2D uses (x-y) as (horizontal respectively vertical 2D) coordinates, but in 2D-axi these are renamed (r-z) that is "why" you need to do the mapping x=>r y=>z but once you have got this trick its easy ;) -- Good luck Ivar
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 23 nov 2012, 04:12 GMT-5
This is a known limitation when revolving a 2D axisymmetric solution into 3D using a Revolution 2D data set and then visualizing vector fields in 3D. But there is a way to get access to the angle phi and convert the cylindrical components into Cartesian components:
In the settings window for the Revolution 2D data set node, under Advanced, select the "Define variables" check box to define the variables rev1phi for the angle phi. You can then (after re-solving or updating the solution), use the following expressions in the text fields for the x, y, and z components:
ht.tfluxr*cos(rev1phi)
ht.tfluxr*sin(rev1phi)
ht.tfluxz
Magnus Ringh, COMSOL
Hi, This is a known limitation when revolving a 2D axisymmetric solution into 3D using a Revolution 2D data set and then visualizing vector fields in 3D. But there is a way to get access to the angle phi and convert the cylindrical components into Cartesian components: In the settings window for the Revolution 2D data set node, under Advanced, select the "Define variables" check box to define the variables rev1phi for the angle phi. You can then (after re-solving or updating the solution), use the following expressions in the text fields for the x, y, and z components: ht.tfluxr*cos(rev1phi) ht.tfluxr*sin(rev1phi) ht.tfluxz Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 23 nov 2012, 04:22 GMT-5
Hi again,
In fact, no re-solving or update of the solution is required.
Hi again, In fact, no re-solving or update of the solution is required. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 23 nov 2012, 07:32 GMT-5
Thanks! :D
Thanks! :D
Posted: 1 decade ago 23 nov 2012, 07:44 GMT-5
Hi Magnus
Thanks, I hadnt tought of that one :)
Hi Magnus Thanks, I hadnt tought of that one :) -- Good luck Ivar
