23 nov 2012, 09:40 GMT-5
I agree it takes some time to get used to these, we have all the same issue, in your case your mesh is not complete, you have not meshed all entities (domains, boundaries ...) check your mesh and see if you should not add a final teth mesh node with the "remaining" selected, then COMSOL finishes off to mesh whatever is left unmeshed
23 nov 2012, 12:02 GMT-5
Thanks for the response I will work with that and hope the situation turn better :)
9 years ago
18 set 2016, 06:22 GMT-4
Hi all,
I am new to Comsol and I am trying to give a 3D laminar flow(spf) with time dependent studies in a cluster. I am using Comsol 5.2 and I am getting the following error.
Current Progress: 0 % - Form Union
Memory: 492/492 2020/2020
Open time: 43 s.
Running: Batch 1
Current Progress: 0 % - Reference 1
Memory: 474/492 2016/2020
Current Progress: 0 % - Free Tetrahedral 1
Number of vertex elements: 0
Current Progress: 0 % - Creating boundary mesh
Memory: 475/492 2092/2092
Current Progress: 0 % - Boundary Layers 1
Memory: 475/492 2096/2096
Current Progress: 0 % - Smoothing transition to interior mesh
Memory: 476/492 2096/2096
/*****Error********/
The following feature has encountered a problem:
Problem setting up multigrid.
Unsupported geometric entity level.
I have tried both Domain decomposition and Multigrid method for the Iterative methods and both methods are giving the same error. Any help would be really appreciated. Thanks in advance.
Hi all,
Open time: 43 s.
Running: Batch 1
