Phase Change Material
Hello! I want to implement a Phase Change Material to run a simulation but I don't know where to find it. Some time ago, I was using an older version of COMSOL and I could find it under the heat transfer in fluids, but it isn't there now in the 6.2 version.
Thanks!
1 Reply Last Post 15 gen 2024, 08:53 GMT-5
Andrii Grytsan COMSOL Employee
Posted: 8 months ago 15 gen 2024, 08:53 GMT-5
Hi Beatriz,
You can find Phase Change Material if you right-click on the "Heat Transfer in Fluids" subnode "Fluid 1" in your Model Builder tree. As an alternative, you can find it in the Ribbon Menu on Physics Tab, in its Attributes section.
Best regards, Andrii Grytsan
Hi Beatriz, You can find Phase Change Material if you right-click on the "Heat Transfer in Fluids" subnode "Fluid 1" in your Model Builder tree. As an alternative, you can find it in the Ribbon Menu on Physics Tab, in its Attributes section. Best regards, Andrii Grytsan
