I don't understand why the ball flies away
Marcus Johansson Certified Consultant
Hi!
I am still beginner for Comsol. When I attempt to simulate, the steel ball flies away from the circular path. I don't know why.
Thanks for the help
1 Reply Last Post 12 feb 2024, 01:00 GMT-5
Soumya S S COMSOL Employee
Posted: 9 months ago 12 feb 2024, 01:00 GMT-5
As the ball is in contact with the inside boundaries of the outer path, you need to select Use inside boundaries for contact for Rigid Body Contact 1.
Hope this helps.
-Soumya
As the ball is in contact with the inside boundaries of the outer path, you need to select **Use inside boundaries for contact** for **Rigid Body Contact 1**. Hope this helps. -Soumya
