Heat transfer in pipes inside a soil/porous media
Posted 1 feb 2024, 11:48 GMT-5 Fluid & Heat, Heat Transfer, Porous Media Flow Version 6.2 0 Replies
Good morning,
In my model I have to model the heat transfer in pipes. Those pipes are placed on a concrete wall and are in contact with the ground (a porous media). When I had the 'heat transfer in solid and liquid interface' and the non-isothermal pipe flow, everything worked pretty well. But If I use 'Heat transfer in a porous media' instead of the ''heat transfer in solid and liquid interface', then the initial temperature in the pipes results in values below the 0°C and, sometimes, the fluid flow but does not exchange heat.
Is it possible that the 'Heat transfer in porous media' does not work well with the pipes?
Thanks to who will answer.
Hello Maria Romana Alvi
