flux along -x
Hi all,
I am doing simulation on waveguides (2D simulation, vertical section).
I calculate the flux along a vertical line.
I would like to control the flux along -x to see if there are some reflections.
Does someone know how I can do?
Thank you very much
Sara Nocentini
1 Reply Last Post 11 dic 2012, 05:48 GMT-5
Posted: 1 decade ago 11 dic 2012, 05:48 GMT-5
I believe you should sketch out or add an image to let us better understand your issue, and do not forget to read carefully the Knowledge base articles about Flux calculations
Hi I believe you should sketch out or add an image to let us better understand your issue, and do not forget to read carefully the Knowledge base articles about Flux calculations -- Good luck Ivar
