Thin Layer boundary in Heat Transfer in Solids can only be modelled via Thick Approximation
Posted 20 feb 2024, 09:39 GMT-5 General, Heat Transfer, Physics Interfaces Version 6.2 1 Reply
I've been using the Heat Transfer in Solids module but noticed that for the Thin Shell (boundary) node the Layer Type drop-down menu only contains the "Thermally thick approximation" option. Is there a possibility that I'm missing a license that is required for any of the remaining 2 options - "General" and "Thermally thin approximation"?
This appears to be the case for 3D, 2D, 2D axisymmetric, and for blank models from scratch.
Kind regards, Alex
