Robert Koslover
Certified Consultant
7 months ago
26 feb 2024, 13:47 GMT-5
Updated:
7 months ago
You need to either take more direct control of your time-steps, specify a smoother transition between on/off current states, or both. There are a variety of ways to do this.
7 months ago
26 feb 2024, 15:05 GMT-5
Updated:
7 months ago
Thank you for your answer. I increased the on/off transition using a smoothing with 2nd derivative and a transition zone of 1s. This did not solve the problem.
Could you expand on what you mean by take a more direct control? So far, I use an implicit solver type with BDF method. Maximum BDF order is 5 and minimum is 1. I tried to force the initial step to better either large (1s) or small (0.001s), but the issue remains. Should I keep BDF method? Or should I switch to explicit?
Thank you in advance.
Robert Koslover
7 months ago
26 feb 2024, 17:35 GMT-5
Updated:
7 months ago
26 feb 2024, 17:34 GMT-5
Consider setting "strict" or "manual" time stepping. If you still can't fix it after a number of tries, consider posting your model to the forum (see "how to reduce MPH-file size" in the small blue print on this page, if necessary) so that those who read here can take a closer look into the details.
