Calculating advective/diffusive fluid flux over a boundary -darcy's law and transport of diluted species module
Posted 3 gen 2013, 15:44 GMT-5 Porous Media Flow Version 4.3a 1 Reply
Currently, I am modeling the transport of diluted species under concentration gradient and pressure differential in the soil which enters the building through foundation cracks. I am using two modules, darcy’s law and transport of diluted species. I have to define a relationship for flux through the crack and the full expression for flux is as below. The dl.w is the q (velocity in z direction from darcy law) :
JT = -c*q*[exp(q*tck/Deff) / (1 - exp(q*tck/Deff))]
After substituting constant values, I am entering it to comsol as:
-dl.w*c*(exp(dl.w*0.156/7.2*10^6)/(1 - exp(dl.w*0.156/7.2*10^6)))
c: concentration of gas, given by comsol
tck: crack thickness
Deff : diffusion coefficient of gas
But the problem is that, the whole expression turns brown and when I run the model, it gives me an error which says in 4000 degrees of freedom has undefined NaN/Inf value. The coordinates for these nodes are exactly located across the crack. The above expression accounts for both advective and diffusive fluxes through the crack. When I neglect the diffusive flux and just use the term: dl.w*c, the solution converges and I can get the average value for flux but this is not the exact value. I am interested in calculating the exact value. I hope you could help me.
Ali
Hello Ali Moradi
