postProcessing for symmetric geometry
There is a 3 d model where only a half of it is simulated. One boundary is a symmetric one. How to plot in the postprocessing the whole model given the only half of it simulated?
4 Replies Last Post 27 mag 2024, 22:25 GMT-4
Posted: 11 months ago 6 mag 2024, 23:32 GMT-4
You can create a mirror dataset, under results. Look that up in the Help system for more info.
Posted: 11 months ago 9 mag 2024, 10:21 GMT-4
thank you
thank you
Posted: 10 months ago 25 mag 2024, 09:03 GMT-4
Updated: 10 months ago 25 mag 2024, 09:04 GMT-4
Dr Koslover in a 3d half model, mirror data 3d can be used to plot 3d stuff. But when plotting 1d curves or 2d surfaces, mirror data 2d doesn't seem to work and there's no mirror data 1d even. How should I plot 1d curves or 2d surfaces by symmetry?
Posted: 10 months ago 27 mag 2024, 22:25 GMT-4
Well, I just tried it and creating a Mirror 2D dataset worked for me. And it worked in much the same way as a Mirror 3D dataset does. So I suggest you post your .mph file and describe specifically what kind of mirror 2D dataset you are trying to build and employ, so that readers will be better able to diagnose why it isn't working for you in your specific problem.
