parameters
Mohamed Aymen Ben Hassen
Hi everyone,
I have a simple question for you.
If I have a variable 'D' , coeficient difusion, depends to temperature (T) with the expression D(T)=0.29*T. the range of temperature is (900 kelvin to 1200 Kelvin with path of 100 K) in another word [900-1000-1100-1200]
How can I do it in comsol ?
thx in advance.
6 Replies Last Post 8 gen 2013, 10:43 GMT-5
Josh Thomas Certified Consultant
Posted: 1 decade ago 7 gen 2013, 08:44 GMT-5
Mohamed,
Simply type: 0.29*T in the edit field for D. Anywhere you can enter values in COMSOL you can also enter expressions.
Josh Thomas
AltaSim Technologies
Mohamed, Simply type: 0.29*T in the edit field for D. Anywhere you can enter values in COMSOL you can also enter expressions. Regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago 7 gen 2013, 08:52 GMT-5
Thank you very much Josh.
Posted: 1 decade ago 7 gen 2013, 09:53 GMT-5
Hi Josh,
ok for the expression but how can I insert the tempreture interval [900 to 1200] ?
best regards
Mohamed
Hi Josh, ok for the expression but how can I insert the tempreture interval [900 to 1200] ? best regards Mohamed
Posted: 1 decade ago 8 gen 2013, 01:04 GMT-5
define a parameter, and either use the Solver "continuation tab, or add a Parametric sweep node before your solver node (right click the study node) and define your parameter to get your value following your sequence, then adapt the BC or local definition for "T" such that it uses the Parameter
Hi define a parameter, and either use the Solver "continuation tab, or add a Parametric sweep node before your solver node (right click the study node) and define your parameter to get your value following your sequence, then adapt the BC or local definition for "T" such that it uses the Parameter -- Good luck Ivar
Posted: 1 decade ago 8 gen 2013, 05:53 GMT-5
Thx Ivar for this response.
Have u an example that explain this steps ? If not, can you please explain with more details ? I can't find the solver "continuation tab"
best regards
Thx Ivar for this response. Have u an example that explain this steps ? If not, can you please explain with more details ? I can't find the solver "continuation tab" best regards
Posted: 1 decade ago 8 gen 2013, 10:43 GMT-5
what about using the help ? try search for "Parametric Study" ;)
Hi what about using the help ? try search for "Parametric Study" ;) -- Good luck Ivar
