Magnus Ringh
COMSOL Employee
11 months ago
22 mag 2024, 08:30 GMT-4
Updated:
11 months ago
22 mag 2024, 08:31 GMT-4
Hi Massimiliano,
The Electrostriction multiphyiscs node is not applicable because the Material type setting is set to Nonsolid in the Settings window for Charge Conservation in the Electrostatics interface. It should be set to Solid in the model domains.
Magnus
Hi Massimiliano,
The **Electrostriction** multiphyiscs node is not applicable because the **Material type** setting is set to **Nonsolid** in the **Settings** window for **Charge Conservation** in the Electrostatics interface. It should be set to **Solid** in the model domains.
Magnus
11 months ago
23 mag 2024, 05:37 GMT-4
thank you for your suggestion, the domains now are ok, but I still find difficult to plot capacitor deformation.
Can you suggest a tutorial? I can find only a lot of piezoelectric examples in the learning center.
Thank you again
Thank you again
Magnus Ringh
COMSOL Employee
11 months ago
23 mag 2024, 06:40 GMT-4
Hello Massimilano,
Plotting deformation is common in structural mechanics models by adding a Deformation subnode to your plot. Its default spatial components are the displacements u
, v
, and w
(in 3D), scaled to show an exaggerated deformation (actual deformations are generally small in comparison to the model geometry). You can change the default scaling if needed.
Magnus
Hello Massimilano,
Plotting deformation is common in structural mechanics models by adding a **Deformation** subnode to your plot. Its default spatial components are the displacements `u`, `v`, and `w` (in 3D), scaled to show an exaggerated deformation (actual deformations are generally small in comparison to the model geometry). You can change the default scaling if needed.
Magnus
