Two PDEs that need to solved alternatively
Anish Kumar Kodyingal
I am trying to solve the Poisson-Nernst-Planck (PNP) equation:
This is not the real set of equations I am solving. This is where I am starting. The idea is that the solver for eqn 1 must step through time and at each step solver for eqn 2 will take input from the time step of eqn 1 and solve for phi. Thus, the overall solver for conc must step through time from 0 to 1s but at each point the Poisson eqn 2 must be solved to get the potential.
How do i achieve this? I have attached the file to give an idea of the equations and methods I am using. The concentration updates correctly at each time step however the eqn 2 does not evolve over time. Can someone help me with this? any help will be greatly appreciated!
2 Replies Last Post 12 giu 2024, 16:04 GMT-4
Posted: 2 months ago 6 giu 2024, 10:42 GMT-4
Updated: 2 months ago 6 giu 2024, 10:43 GMT-4
Solve both equations in a single, time-dependent, solution step. See the attached file.
Jeff Hiller
Solve both equations in a single, time-dependent, solution step. See the attached file. Jeff
Posted: 2 months ago 12 giu 2024, 16:04 GMT-4
Hi Jeff,
Thank you so much for your swift response and help! You are an absolute life saver it works now. Appreciate your help :)
Hi Jeff, Thank you so much for your swift response and help! You are an absolute life saver it works now. Appreciate your help :)
Reply
