Extracting frequency dependent matrices (of a nonlinear eigenvalue problem)
Posted 24 giu 2024, 11:40 GMT-4 0 Replies
The below post is related to an archived discussion
I'm trying to extract (via Matlab LiveLink) the matrices from a nonlinear eigenvalue problem stemming from a physical model.
The stiffness and damping matrices of the problem are frequency dependent (as in the linked discussion), hence, I want to extract the matrices evaluated at a particular eigenvalue linearization point. Unfortunately, I'm not getting the correct matrices using the expect command:
mphmatrix(model,'sol1','out',{'K','E','D'},'complexfun','on','eigname','lambda', 'eigref',eigref)
(Solving the eigenvalue problem using the extracted matrices, does not give me the same results from the COMSOL solver)
I am missing some subtle detail?
Thanks in advance,
Filipe Soares
Hello Filipe Soares
