How To Create A Coefficient That Depends On Water Content
Dear all,
I'm dealing with a 2 coupled PDE problem, related with diffusion of water in porous media, where the two variables are the temperature and the relative humidity.
I want to introduce a thermal conductivity which depends on the water content, k(w), but once I define it, it says that "I don't know what's w". I also defined w as an analytic function dependent on the relative humidity.
My question is: Can I define a coefficient that depends on a variable? (Apart from P or T)
Thanks a lot. Regards,
1 Reply Last Post 28 giu 2024, 09:56 GMT-4
Posted: 4 months ago 28 giu 2024, 09:56 GMT-4
Hello Junhyeok,
If the relative humidity is "c", then your call to k should read something like k(w(c)). Give it a try, and post your mph file, with the mesh and solution cleared, if that does not resolve it.
Jeff Hiller
Hello Junhyeok, If the relative humidity is "c", then your call to k should read something like k(w(c)). Give it a try, and post your mph file, with the mesh and solution cleared, if that does not resolve it. Best, Jeff
Reply
