Pressure acoustics scaling factor
Can somebody please explain the purpose of the scaling factor in the pressure acoustics interface?
I see in the acoustics module user guide that it says the default scaling factor is 1/omega^2, but I don't understand why this is the scaling factor or what its purpose is or how it affects results.
3 Replies Last Post 8 lug 2024, 04:20 GMT-4
Acculution ApS Certified Consultant
Posted: 5 months ago 8 lug 2024, 03:28 GMT-4
I believe this is for improved accuracy. If certain terms in a equations are emphasized due to a frequency term, it might be beneficial to apply a scaling. You can always set it to 1 and to the default and then compare results across a wide frequency range.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 5 months ago 8 lug 2024, 04:14 GMT-4
Thanks, René. I am not sure I understand how this affects accuracy, do you know where I can read more about this.
I was modelling acoustic resonance and found that the resonance frequency of my system was around 0.5 MHz higher with the scaling set to 1.
>I believe this is for improved accuracy. If certain terms in a equations are emphasized due to a frequency term, it might be beneficial to apply a scaling. You can always set it to 1 and to the default and then compare results across a wide frequency range. Thanks, René. I am not sure I understand how this affects accuracy, do you know where I can read more about this. I was modelling acoustic resonance and found that the resonance frequency of my system was around 0.5 MHz higher with the scaling set to 1.
Magnus Ringh COMSOL Employee
Posted: 5 months ago 8 lug 2024, 04:20 GMT-4
Hi Peter,
In general, numerical calculations benefit from terms of about equal magnitude. Here is an overview of what's called "error cancellation" (for example, when two terms have markedly different magnitude): https://www.sciencedirect.com/topics/engineering/error-cancellation.
Magnus
Hi Peter, In general, numerical calculations benefit from terms of about equal magnitude. Here is an overview of what's called "error cancellation" (for example, when two terms have markedly different magnitude): . Best regards, Magnus
Reply
