Concentration Constrain on Transport of Dilute Species Simulation
I am doing a simple simulation of ion diffusion and drift using the Transport of Dilute Species module and the Electrostatics module. I was wondering, is there a way to restrict the concentration or to place a constrain on the concentration so that inside the surface (I'm doing a 2D simulation) over which the ions are diffusing and drifting the concentration does not exceed a certain value (that I would input)? I want to do this basically because as the ions drift to one side of the surface and reach the side, the concentration increases extremely fast and there seems to be no way to restrict how much the concentration can be in a given place.
Thank you for any help you can provide me.
1 Reply Last Post 17 gen 2013, 15:34 GMT-5
Posted: 1 decade ago 17 gen 2013, 15:34 GMT-5
certainly you could add some math function to limit the concentration, but is that physical ?
It would be better to identify and use a constitutional equation describing the physical phenomena that avoids the concentration to go above some value. There must e some non linear diffusion effects ongoing, but I'm no chemist so I'm neither not sure where to start ;)
Hi certainly you could add some math function to limit the concentration, but is that physical ? It would be better to identify and use a constitutional equation describing the physical phenomena that avoids the concentration to go above some value. There must e some non linear diffusion effects ongoing, but I'm no chemist so I'm neither not sure where to start ;) -- Good luck Ivar
