Plotting the frequency vs displacement response for a mesh or node
Dear forum,
I am trying to simulate the frequecy responce of a piezoelectric device. It seems I was able to successfully set the piezoelectric properties, electrostatic conditions, and run the frequency domain study. Now I am trying to plot its frequency responce at certain positions using 1D plot (for example with respect to the center of one side of the piezo device), but I realized that I can only select the 'points' of the model. Is there any way I can slect a certain mesh or perhaps its node and plot its frequency response?
Thanks, new COMSOL user
2 Replies Last Post 21 lug 2024, 04:41 GMT-4
Posted: 9 months ago 20 lug 2024, 11:41 GMT-4
There are two easy ways to do this
1 Add points to the geometry at the location(s) of interest
2 Define a 2D or 3D cut point under Datasets. Then under Derived Values add a Point Evaluation sub-node.
There are other more automated ways to accomplish the same thing (probes, for example).
There are two easy ways to do this 1 Add points to the geometry at the location(s) of interest 2 Define a 2D or 3D cut point under Datasets. Then under Derived Values add a Point Evaluation sub-node. There are other more automated ways to accomplish the same thing (probes, for example).
Posted: 9 months ago 21 lug 2024, 04:41 GMT-4
Dave,
Thanks for your quick reply, it was easy as you said! Appreciate your help.
Dave, Thanks for your quick reply, it was easy as you said! Appreciate your help.
