parametrize the position of a point in the geometry gives an error message
Dear Comsolfriends,
I want to do a parameter study for the size of my geometry, but I get the following error when trying to set the position of a POINT using a parameter defined before in MATLAB (directly in comsol this problem does not occur) -- for circles etc everything works fine in matlab, but for points the trouble starts:
model.param.set('cx','1'); model.param.set('px','1');
model.geom.create('geom1', 2);
model.geom('geom1').feature.create('c1', 'Circle');
model.geom('geom1').feature.create('pt1', 'Point');
model.geom('geom1').feature('c1').set('pos', {'1' '1'});
model.geom('geom1').feature('pt1').set('p', {'1'; '1'});
this works fine, as well as
model.geom('geom1').feature('c1').set('pos', {'cx' '1'});
but if I try
model.geom('geom1').feature('pt1').set('p', {'px'; '1'});
I get the error message:
Error using com.comsol.model.impl.GeomFeatureImpl/set
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Unknown variable name
- Name: px
- Property name: p
Stack trace:
at com.comsol.util.classes.o.a(Unknown Source)
at com.comsol.util.classes.o.b(Unknown Source)
at com.comsol.nativeutil.parser.ParseUtil.e(Unknown Source)
at com.comsol.nativeutil.parser.ParseUtil.a(Unknown Source)
at com.comsol.nativeutil.properties.ak.set(Unknown Source)
at com.comsol.model.impl.PropValueImpl.set(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl.c(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.a(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl$d.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
has anyone an idea why this happens? where is the big difference between a point and a circle? did you try something similar, and, above all, HOW TO SOLVE THIS? I want a geometry with a point at the middle of one boundary, and when I sweep the size of my geometry, the point must move as well of course.
Thanks a lot for any answer!!! :)
Sabine
0 Replies Last Post 22 gen 2013, 09:52 GMT-5
Hello Sabine
