28 gen 2013, 09:30 CET
Hey,
my guess is:
- you don't see any flux lines because there is no magnetic flux
- as you can find in postprocessing, magnetic flux density and magnetic vector potential is zero in your whole model
- the reason for this might be that there is no source term in your magnetic and electric fields interface
- try to bring an electric current density source into that interface with the current density from the electric currents interface (ec.Jx, ec.Jy, ec.Jz) as the source expression terms
By the way I don't understand your model. You have applied a voltage of 300 V to the edges of the cylinder along its sides. This goes straight to the grounded boundary. I am not sure if this is intended, but it doesn't seem to be physically correct.
On the other hand there is maybe some conversion error, since I opened your version 3.5 model with my 4.3 installation...
AFAIK the helix primitive was introduced in a later version than 3.5, maybe 4.1 or 4.1a. In an earlier version you can create a helix with some more effort, like approximating it with other primitives, using CAD import or a suitable MATLAB script...
Hey,
my guess is:
29 gen 2013, 02:27 CET
Hey,
thanks for the reply! I figured there was no flux on the model at all, but then now my question is how to I make it? I tried adding currents in a) subdomain settings, Qj and Je b) boundary settings by defining the 4 cylinder boundaries of 'current flow' type and defining currents there two.
I would have thought that one of these methods would have allowed current to flow along the cylinder (due to the potential across it) and thereby created a field. Am I missing something?
Would you be able to explain what you mean by this:
note: I did take the global equations and constants from the 'rail gun' comsol model; would this be a problem? Again, I am very unfamiliar with Comsol so I am not sure what I need to define or not in order to get this to work.
Thanks!
Jonathan
Hey,
Thanks!
Jonathan
29 gen 2013, 11:26 CET
Okay, I think I cannot open and modify your model properly, since it was created with version 3.5 and I do not know what the intention of your simulation is.
But what I meant is that the magnetic interface, which solves for the magnetic vector potential and consequently yields your desired quantity magnetic flux density, has no source term, no excitation. So it won't find a quantity different from zero. I guess a possible excitation would be to use the current density from the electric currents interface. You define some electric potential BCs there that yield a current density, you can visualize that in postprocessing. Using this in the magnetic interface as a source will result in a magnetic field.
Then I saw that you didn't assign a material, but without a material parameter permeability you cannot get a magnetic flux density, because this is B = µ*H.
So try the following:
1) add a source to your magnetic interface
2) add a material with a permeability
