a time step's solution for initial value of next step in time-dependent solvers
hi,
how can we use a solution for a time step, for instance range(0, 0.1 s), to next time step's [ now it is range ( 0.1, 0.2 ) ] initial value in time-dependent solvers?
current solution - stored solution?
2 Replies Last Post 26 feb 2010, 01:58 GMT-5
Posted: 1 decade ago 25 feb 2010, 13:03 GMT-5
Just change your time range and click on "restart" : this is the naive way!!
Another alternative : You have "solution at time" option in the solver manager, so select current solution and specify at which time step you want (generally the latest one)
I hope it helps
Cheers,
Hi, Just change your time range and click on "restart" : this is the naive way!! Another alternative : You have "solution at time" option in the solver manager, so select current solution and specify at which time step you want (generally the latest one) I hope it helps Cheers,
Posted: 1 decade ago 26 feb 2010, 01:58 GMT-5
hi,
thank you for your helps,
second one works quite well.
hi, thank you for your helps, second one works quite well.
