29 gen 2013, 14:36 GMT-5
You need to be more specific. What physics are you using? Are you in 2D or 3D? How are you simulating the particles. If you upload your .mph file it can help others get a better idea of what you're trying to do.
12 mar 2013, 11:14 GMT-4
I met the same problem. I built a simple 2D model with laminar flow. The channel width is 1 micro meter. But the particle with 5 micro meter diameter can go through it.
21 gen 2015, 01:24 GMT-5
I have a similar problem as you. Why the large particle can go through smaller channel size ?
I did 3D geometry, Physics: particle tracing
I have changed the particle size, but particle size in the animation is same.
Walter Frei
COMSOL Employee
12 feb 2015, 14:29 GMT-5
Hello All,
Keep in mind that the Particle Tracing for Fluid Flow assumes that the particle diameters are negligible compared to the other dimensions in your model. Of course, if the particle is larger than the channel, we know it won't go through the channel and the analysis is moot. Particles which are a significant fraction of, but still smaller than, the channel width can be treated with a Moving Mesh interface.
Hello All,
10 years ago
31 mag 2015, 20:52 GMT-4
Hello All,
Hi Walter,
I tried to use Moving Mesh and it worked with a single particle. However, when I introduced another one, once the particle hit the wall of flow channel, or the two particles were about to collide with each other, it stopped running. Would you please give me some advice to solve that? Thanks a lot.
tianhang
[QUOTE]
Hello All,
[/QUOTE]
Hi Walter,
tianhang
