Out of memory during LU factorization
Posted 27 set 2024, 11:47 GMT-4 9 Replies
Could you help to understand what is wrong in my model? I get not converged solution error. You can find the model in attachment
Looks like you are simply running out of memory. There are many ways to address this. See https://www.comsol.com/support/knowledgebase/830 and https://www.comsol.com/support/knowledgebase/1030
-------------------Scientific Applications & Research Associates (SARA) Inc.
Hi, my mesh is composed by about 1400000 tetrahedral elements (i suppose they are linear tetrahedral, let me know if there is a way to check). I have 4 dependent variables (electric field components and 1 S-parameter), so the number of degrees of freedom should be 0.2*1400000*4= 1200000 more or less. So less than 5 Gb of Physical memory should be enough according to comsol documentation (https://www.comsol.it/blogs/much-memory-needed-solve-large-comsol-models). The Log of my simulation says this
Compile Equations: Frequency Domain in Study 1/Solution 1 (sol1) ---------
Started at Sep 30, 2024, 4:10:09 PM.
Geometry shape function: Quadratic Lagrange
Running on 4 x Intel(R) Xeon(R) Gold 6154 CPU at 3.00 GHz.
Using 4 sockets with 2 cores in total on rat4.rfx.local.
Available memory: 773.70 GB.
Canceled
Time: 9 s.
Physical memory: 6.36 GB
Virtual memory: 21.79 GB
Ended at Sep 30, 2024, 4:10:18 PM.
----- Compile Equations: Frequency Domain in Study 1/Solution 1 (sol1)
So it looks like it is using more than 6 GB and still is going out of memory. Why?
As you can see in the attached printout, you are using second-order elements. So the DOF count is much larger. The number of DOF is printed in the Messages tab when you start the analysis.
You select the order of the elements in the Discretization section in the settings for the physics interface.
-------------------Henrik Sönnerlind
COMSOL
With linear discretization it takes about 32 GB and it completes. The mesh may be finer than needed. You can save a lot of memory by adjusting the mesh.
-------------------Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Ok thank you for the help. I have another doubt, as you can see my model is perfectly symmetryc with respect to the zx plane, so I wonder If can simulate only half of my geometry to save computational resources and time. I already did this in other models, but the problem now is that on the symmetry plane my fields (the fields of a input TE10 mode) are both tangent to the plane, so I can't use PMC or PEC boundary conditions, rigth?. What boundary condition would you suggest me to use in this case?
Thank you in advance
The E-field is perpendicular to the symmetry plane, no?
www.emphys.com
Yes you are right, my mistake. Now I have to do a bigger simulation where I can't cut my domain in two because I have to excite a combination of different modes at the antenna port, and so I have a very large DOF number (about 40000000). Which solver would you suggest to use when having such high DOF number? I already switched to linear discretization, and I can't further reduce my mesh accuracy otherwise I won't catch the physics of the problem (radiation pattern of antenna with mode converted input at frequency >80 GHz). A strategy could be to try to use hexahedral mesh, but it looks very complicated with my geometry. I have about 90 GB at maximum to use on the server where I am working. Could an iterative solver be better than PARDISO?
Using an iterative solver is the only possibility you have for solving very large problems.
Have you considered the possibility to split the problem into one symmetric and one antisymmetric using different sets of boundary conditions? Any linear problem on a symmetric geometry can be considered as a superposition of a symmetric and an antisymmetric solution.
COMSOL
Henrik's suggestion of superposing a symmetric and antisymmetric solution worked for me in very big acoustic models. These models were geometrically symmetric but the wave excitation was not. It saves half the memory and also half the solution time.
www.emphys.com
Reply
Discussion Forum Rules and Guidelines
The goal of COMSOL Access is to provide a forum for you to communicate effectively with COMSOL as well as your colleagues within the multiphysics simulation community. This involves providing you with access to technical support and downloads of the latest {:comsol} software releases, as well as the ability to share your comments and work with other users of the {:comsol} software through forums such as the blog, discussion forum, and Application Exchange. In order to make this an efficient and pleasant experience for you and other members of COMSOL Access, we ask that you follow a few rules and guidelines.
When registering for COMSOL Access, you agree to provide your complete and truthful information for all fields requested on your COMSOL Access account registration page. You also agree to maintain the accuracy of all information associated with you on your COMSOL Access account. You agree to maintain your COMSOL Access account for use solely by you, not to share your username and password with anyone else, and to take appropriate precautions to restrict access to your username and password from others. Furthermore, you agree not to submit any information relating to your employer through your COMSOL Access account without your employer’s authorization. Should you use a COMSOL Access account associated with an employer, you agree to immediately discontinue using that account upon termination of that employment.
The moderators of the forums will remove any generally objectionable material as quickly as possible. You acknowledge that all posts made to these forums express the views and opinions of the author and not the administrators, moderators, or webmaster (except for posts by these people). Hence, they will not be held liable.
You agree not to post or link to any material that is abusive, obscene, vulgar, slanderous, hateful, threatening, sexually oriented, or that infringes upon or violates any third-party rights or any other material that may violate any applicable laws. You agree that you will not otherwise use your COMSOL Access account to violate or to assist anyone in violating any law. Engaging in any activity in violation of these COMSOL Access rules and guidelines may lead to you being immediately and permanently banned from COMSOL Access. The IP address of all posts is recorded to aid in enforcing these conditions. You agree that the webmaster, administrator, and moderators of the forums have the right to remove, move, or close any topic at any time as they see fit. As a user of COMSOL Access, you agree to any information you have entered into any of the forums being stored in a database.
You agree that you will not use your COMSOL Access account in violation of any applicable export control laws. You represent and warrant that you are not subject to any comprehensive sanction or embargo by the U.S. or any other country, nor are you identified on any list maintained by the U.S. government that identifies persons for which the U.S. maintains restrictions. Further, you represent and warrant that you are not subject to any restriction on the receipt of technology or products under the export control laws of the U.S. or any other country.
Basic Rules
- Flaming: Do not post any messages that harass, insult, belittle, threaten, or flame another member or guest. Debates are fine, but argue with the point, not the person.
- Trolling: Do not post with the purpose of starting a dispute. Note that a person disagreeing with your opinion is not considered trolling; keep it civil, even if you are sure that the other person is wrong. Anything seen as trolling will result in you being banned.
- Spamming: Posts without content or containing nonsense waste space and everyone's time. Spam will be removed from the forum.
- Offensive Posts, Links or Images: Do not use profanity, racial, ethnic, religious, or other slurs or any other offensive material.
- Advertising: Posting of advertisements for products or services, links to auctions, affiliate links, links to promote websites, and so forth is not allowed.
- Disclosure of Personal Information: Do not disclose any other member's email, real name, address, phone number, IP address, or other personal information. This includes posting contents of emails and private messages without the sender's consent. Do not bring personal disputes into the forums. Bans and warnings issued to other users are considered personal information.
- Misleading Titles: The subject line of the post should be as informative as possible about the content of the post. This also reduces the amount of duplicate posts.
- Thread Hijacking: Taking a thread off-topic to pursue one's own agenda is not permitted.
- Piracy: Do not upload, post, email, transmit, or otherwise make available any content that infringes upon any patent, trademark, trade secret, copyright, or other proprietary rights ("Rights") of any party. This includes COMSOL model files created by a forged or illegitimate license.
- Honesty: Users must provide truthful information in creating their COMSOL Access account.
These rules are subject to change. The moderators reserve the right to remove, edit, or move posts at their discretion. The COMSOL Access administrators will reserve the right to permanently remove a user account without notice if any of the rules are not followed. Particular services accessible with your COMSOL Access account may be subject to additional rules. You agree to comply with all rules applicable to each service you access through your COMSOL Access account.
Posting Guidelines
When posting, understand that you are trying to communicate with other people. Although many COMSOL Access members are not fluent in English, the official language of this forum is English.
Here are some important guidelines of language:
- Write in English.
- If you are familiar with LaTeX, please use this to write mathematical equations.
- Always do a quick check for spelling/grammar mistakes.
- Format your post in a legible manner. Use the Preview button often.
- Be concise and articulate as much as possible.
- Use the Enter key to create paragraphs.
- Capitalize correctly. It is difficult to read posts that are written entirely in uppercase or lowercase.
- Use correct punctuation. Avoid run-on sentences.
- Try to avoid using “text speak”, “net speak”, or slang. The purpose of language is to be understood.
- Never invent acronyms and use as few acronyms as possible. For example, write "COMSOL Multiphysics" and not "CMP".
- Review your post before publishing it. Try to catch typos.
- Please check to see if a topic has already been posted. Do not post multiple threads on the same topic.
Disclaimer
By submitting content to the forums, you hereby grant COMSOL a nonexclusive, royalty-free, perpetual, worldwide, and unrestricted license to reproduce, publicly display, publicly distribute, and prepare derivative works of the content. COMSOL hereby grants you a license to copy and/or use content from the forums solely for your own internal purposes. COMSOL provides the forum service for the benefit of our users to share content with the community. All content is provided "as is" without warranty of any kind, express or implied, including without limitation, warranties of merchantability, noninfringement, design, operation, and fitness for a particular purpose, and the entire risk as to the quality and performance of the programs is with you.
Neither COMSOL, the authors, nor the copyright owners of submitted materials warrant that the programs will be error-free, uninterrupted, virus-free, secure, and suitable for your needs, produce specific results, or that errors or failures will be corrected. Comments on supplied content should be sent to the author or copyright owner through the tools provided in the forums.
