Heaviside function simulate Acoustic emission signal
I need to apply a Heaviside function difference to simulate a Acoustic emission burst signal. Can help, how can I do this? What model should I use? I'm new working with COMSOL.
Nuno Gueiral
5 Replies Last Post 4 feb 2013, 09:26 GMT-5
Posted: 1 decade ago 30 gen 2013, 13:10 GMT-5
the Heavyside functions of 3.5 are now readily available as Definitions - Functions : such as step, or rectangle or ramp ... , all with smoothing
Hi the Heavyside functions of 3.5 are now readily available as Definitions - Functions : such as step, or rectangle or ramp ... , all with smoothing -- Good luck Ivar
Posted: 1 decade ago 31 gen 2013, 12:45 GMT-5
I'm using de COMSOL 4.2a version.
Gueiral
Hello, I'm using de COMSOL 4.2a version. Best regards, Gueiral
Posted: 1 decade ago 1 feb 2013, 00:52 GMT-5
in v4 look under Model - Definitions - Functions, and check the step, rect or ramp functions, these have Heavyside smoothing included
Hi in v4 look under Model - Definitions - Functions, and check the step, rect or ramp functions, these have Heavyside smoothing included -- Good luck Ivar
Posted: 1 decade ago 1 feb 2013, 17:07 GMT-5
The ramp function worls perfectly fine, but if your lazy like me and u use the Heaviside function often, its easier to use COMSOL's inbuilt Heaviside function
flc1hs(X,scale)
Hi The ramp function worls perfectly fine, but if your lazy like me and u use the Heaviside function often, its easier to use COMSOL's inbuilt Heaviside function flc1hs(X,scale)
Posted: 1 decade ago 4 feb 2013, 09:26 GMT-5
Tank you Stevie for your answer.
I need to insert in COMSOL a function or a expression like this:
f is a impact force
f = F_max [flch2(t,t_rise )-flch2(t-t_width ,t_fall )]
where
F=max( F )/ S_max ( N / m 2 )
and
S_max=pi*(2.5e-3/2)^2
F : maximum force (2-5N)
and I don't know how? Could you help me?
Best Regards
Nuno
Hello, Tank you Stevie for your answer. I need to insert in COMSOL a function or a expression like this: f is a impact force f = F_max [flch2(t,t_rise )-flch2(t-t_width ,t_fall )] where F=max( F )/ S_max ( N / m 2 ) and S_max=pi*(2.5e-3/2)^2 F : maximum force (2-5N) and I don't know how? Could you help me? Best Regards Nuno
