Changing the axis of symmetry in 2D domains
The below post is related to an archived discussion
Hello, from the archived discussion above, I understand that changing the axis of symmetry was not possible 5 years back. I would like to know if it is possible now in version 6.1, and if so, how?
Otherwise, my query is:
I want to create a cylindrical domain where the axis of symmetry is along the z-axis, and not in radial direction. How can I do this?
Thanks in advance!
6 Replies Last Post 16 ott 2024, 03:20 GMT-4
Posted: 2 months ago 29 set 2024, 10:59 GMT-4
Isn't that planar symmetry?
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Acculution ApS Certified Consultant
Posted: 2 months ago 30 set 2024, 03:43 GMT-4
The axis of symmetry is indeed the z-axis already, so perhaps you mean that you would like to have it be the r-axis? Could you explain the need for this? Can you not just rotate the geometry to fit the default axes?
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 1 month ago 15 ott 2024, 11:10 GMT-4
Hello @Acculation ApS,
yes, I would like to have a circle drawn in the radial direction, with properties defined in the same direction. Can you help me to understand how i can "rotate the geometry to fit the default axes"?
Hello @Acculation ApS, yes, I would like to have a circle drawn in the radial direction, with properties defined in the same direction. Can you help me to understand how i can "rotate the geometry to fit the default axes"?
Posted: 1 month ago 15 ott 2024, 12:31 GMT-4
The description is confusing. I strongly encourage you to draw and post a picture of the circle that you are talking about, along with the axes. Also, please be sure to label the axes.
Posted: 1 month ago 15 ott 2024, 15:12 GMT-4
Shubrha,
I don't understand your latest post either.
To create an axisymmetric model of an object that in real life is cylindrical, in COMSOL, after specifying in the Model Wizard that your model is 2D axisymmetric, you would draw a rectangle in the Graphics window. If you were to draw a circle instead, that would correspond to a real life torus.
Jeff Hiller
Shubrha, I don't understand your latest post either. To create an axisymmetric model of an object that in real life is cylindrical, in COMSOL, after specifying in the Model Wizard that your model is 2D axisymmetric, you would draw a rectangle in the Graphics window. If you were to draw a circle instead, that would correspond to a real life torus. Best, Jeff
Posted: 1 month ago 16 ott 2024, 03:20 GMT-4
Sounds like you want to draw a circle to represent a cylinder, in which case I assume you want to look at the cross-sectional field variations only. If that is true, then you want to go with 2D, not 2Daxi.
Acculution ApS
www.acculution.com
info@acculution.com
Reply
