Josh Thomas
Certified Consultant
31 gen 2013, 15:30 GMT-5
Carl -
Click on the plot group node in the Model Builder window and, in the Settings window, expand the Title section.
For Title type, select Custom. Then under Solution, check the Solution check box. This should show the time step or parameter value in the Title of your plot.
Josh Thomas
AltaSim Technologies
Carl -
Josh Thomas
31 gen 2013, 16:35 GMT-5
Carl -
Josh Thomas
Thanks, Josh.
I've already tried that. It didn't change even after replotting.
[QUOTE]
Carl -
Josh Thomas
[/QUOTE]
Thanks, Josh.
Josh Thomas
31 gen 2013, 16:57 GMT-5
Just to be sure. Did you click on the head Plot Group node and click the Solution check box under Title? The reason I ask is because I see that your screenshot shows that the Surface plot node is selected rather than the parent node.
Otherwise, I'm not sure what's happening. Would you be willing to post your mph file?
Josh Thomas
Josh Thomas
Josh Thomas
1 feb 2013, 11:11 GMT-5
Carl,
Okay. I think I might have an answer.
Set the Data set of your Surface plot to "From parent". Then, set the Data set on the Plot Group node (the parent) to the Solution that has your parametric sweep.
When you do this you should be able to get the parameter name and value displayed in the title for your animation.
I got this to work on one of my models. Let us know if that works for you.
Josh
Carl,
Josh
20 mag 2013, 21:20 GMT-4
I had the same problem.
The solution works for me. Thanks a lot Josh!
31 mag 2013, 16:06 GMT-4
Hi Josh,
Thank you, I had the same pb. Now it is OK.
Best regards
Hi Josh,
Best regards
