I have discovered a potential bug
After adding the two physics interfaces for mass transfer in porous media (tds) and solid mechanics(solid), I found that the hygroscopic expansion module(hs1) cannot select the object from the multiphysics point. It seems to be a clear bug.
However, by replacing the physical field of mass transfer in porous media with the physical field of mass transfer, the problem is solved naturally
2 Replies Last Post 17 ott 2024, 02:46 GMT-4
Posted: 3 days ago 16 ott 2024, 04:02 GMT-4
Thanks for reporting. We have verified the error you have described, and will release a correction as soon as possible.
Henrik Sönnerlind
COMSOL
Posted: 2 days ago 17 ott 2024, 02:46 GMT-4
Thank you so much, and I look forward to hearing this great news soon.
>Thanks for reporting. We have verified the error you have described, and will release a correction as soon as possible. Thank you so much, and I look forward to hearing this great news soon.
Reply
