COMSOL cluster sweep with separated output files from command line
Hi all,
Is it possible in Comsol to set up a distributed parametric sweep on a cluster and get the separated output model files, similar to batch sweeps on local? As I understand, this functionality is available only via the GUI mode, and it's not possible for me to launch cluster jobs this way. The other option is cluster batch calls via command line, which only generates a combined single file and not a separate file for each parameter. Will appreciate if someone can help me on this.
Best Regards Amit
0 Replies Last Post 29 ott 2024, 14:20 GMT-4
Hello Amit Kunte
Reply
