Stop an eigenfrequency problem, and resume later
Hello
I want to know if there is the possibility to stop an eigenvalue problem and be able to resume it after that. I am running an eigenvalue problem in Pressure Acoustic module. I dont see any "Stop" button in the "Progress" tab.
For a frequency response study I could stop the simulation in the middle of the run using the "Stop" button and observe the already calculated results. However I didnt resume the simulation.
2 Replies Last Post 18 nov 2024, 15:42 GMT-5
Posted: 4 hours ago 18 nov 2024, 13:40 GMT-5
Provided you have saved the .mph file before running (always a good idea) you can use the (windows) task manager.
Inelegant but effective.
Provided you have saved the .mph file before running (always a good idea) you can use the (windows) task manager. Inelegant but effective.
Posted: 2 hours ago 18 nov 2024, 15:42 GMT-5
And so it is possible to pause a simulation and resume from the last calculated iteration at a later point of time? Can you explain more on the steps what I should do after terminating the task in Task Manager?
Reply
