Using standard deviation operator in optimization objective function
Hello.
I want to define standard deviation of temperature distribution of the load after 60 seconds of heating **( time at 60s) ** as objective function in shape optimization module.
My study is consists of two steps, frequency domain and time dependent.
I made integration operation of the domain of the load in non local coupling section, intop2 Then i could get standard deviation at specific time (60s) by defining Derived values - global evaluation using stddev() built in operator, stddev('comp1.intop2',T).
However, I have no idea how to define objective function using stddev('comp1.intop2',T). stddev() does not work here. Also, I am struggling how to define standard deviation of temperature at specific time as objective function.
I appreciate any advice.
2 Replies Last Post 11 dic 2024, 00:50 GMT-5
Kristian Ejlebjærg Jensen COMSOL Employee
Posted: 5 months ago 25 nov 2024, 09:47 GMT-5
Updated: 5 months ago 25 nov 2024, 09:52 GMT-5
Hi Sujeong
The stddev operator is just an integration operator behind the scenes as described in the documentation, which contains an error, but it should say stddev('comp1.intop1',X) = sqrt(comp1.intop1((X-comp1.intop1(X)/comp1.intop1(1))^2)/comp1.intop1(1)), so you can just make your own variable equal to the standard deviation (you are allowed to have an integration operator inside another integration operator).
Optimization of time dependent problems only support evaluation of the objective function at the final time (except for parameter estimation), because there is no reason to continue the computation beyond the point where the objective is evaluated. If you want to integrate in time, you can use an ODE. The library model tesla_microvalve_transient_optimization demonstrates this.
Kristian E. Jensen
Technical Product Manager, Optimization
Hi Sujeong The stddev operator is just an integration operator behind the scenes as described in the [documentation](https://doc.comsol.com/6.2/docserver/#!/com.comsol.help.comsol/comsol_ref_definitions.19.029.html%232150205), which contains an error, but it should say stddev('comp1.intop1',X) = sqrt(comp1.intop1((X-comp1.intop1(X)/comp1.intop1(1))^2)/comp1.intop1(1)), so you can just make your own variable equal to the standard deviation (you are allowed to have an integration operator inside another integration operator). Optimization of time dependent problems only support evaluation of the objective function at the final time (except for parameter estimation), because there is no reason to continue the computation beyond the point where the objective is evaluated. If you want to integrate in time, you can use an ODE. The library model tesla_microvalve_transient_optimization demonstrates this. Best regards, Kristian E. Jensen Technical Product Manager, Optimization
Posted: 4 months ago 11 dic 2024, 00:50 GMT-5
Hello. It worked! thank you so much.
Reply
