Solid mechanics and element settings
Hi!
I am analysing stresses and displacements of simple 2D steel plate with Comsol 4.2. I need to get results calculated by triangle linear plane stress elements for comparison.
How can I change element type to linear? Comsol seems to use quadratic elements by default?
2 Replies Last Post 10 feb 2013, 10:21 CET
Posted: 1 decade ago 9 feb 2013, 16:02 CET
yes COMSOL uses 2nd order (mostly) elements, this is under "Discretization" tab of your main physics node, but it appears only if you turn the extra view mode on: check your "options parameters" and turn discretization view "on" (there are several others there to once you start to understand the details to COMSOL, I run with all on ;)
but it makes your screen full of tabs you do not always need to access
Hi yes COMSOL uses 2nd order (mostly) elements, this is under "Discretization" tab of your main physics node, but it appears only if you turn the extra view mode on: check your "options parameters" and turn discretization view "on" (there are several others there to once you start to understand the details to COMSOL, I run with all on ;) but it makes your screen full of tabs you do not always need to access -- Good luck Ivar
Posted: 1 decade ago 10 feb 2013, 10:21 CET
Thanks Ivar! I got it now.
Student
Engineering Mechanics
Thanks Ivar! I got it now. -- Student Engineering Mechanics
