Failed to find the consistent initial values
Dear sir,
I am getting an error after solving as follows
"Failed to find the consistent initial values
- Feature : Time - Dependent Solver1 (sol1/t1)
- Error : Failed to find consistent initial values"
We suppose that the error is because of the fact that I am unable take back the results from 1440th time step to 0th time step (with an interval of 5 min each). Is that correct and how can I use the results of the 1440th minute back in oth minute for accurate values??
If not, what are the probable corrections for this error??
And, we have a prolonged query about the varying temperature of the fluid as it flows through the pipes. As the fluid flows through the pipe, the initial values of fluid temperature my vary from position to position. So, Can you let me know about how to incorporate this condition in the model of ours??
Thanking You sir.
Nithin
3 Replies Last Post 18 set 2015, 06:42 GMT-4
Posted: 1 decade ago 12 feb 2013, 11:05 GMT-5
if you do time transient solving in "automatic time steps" the COMSOL sover is set up for diffusion type solvers, so it expects to be able to take larger and larger steps, ut if you introduce periodic BC conditions, the solver might step over a transition.
Try the solver settings time stepping (far down in the solver tree) and use intermefdiate or strickt (check the doc) and be sure a few steps are on the transitions. Then use "smooth transitions, "step" funcions, and NOT Dirac steps
Hi if you do time transient solving in "automatic time steps" the COMSOL sover is set up for diffusion type solvers, so it expects to be able to take larger and larger steps, ut if you introduce periodic BC conditions, the solver might step over a transition. Try the solver settings time stepping (far down in the solver tree) and use intermefdiate or strickt (check the doc) and be sure a few steps are on the transitions. Then use "smooth transitions, "step" funcions, and NOT Dirac steps -- Good luck Ivar
Posted: 1 decade ago 14 feb 2013, 23:55 GMT-5
Sir..
I have made the corrections suggested by you in the above comment. But still, the problem persists. I request you to have a look of the model in the link and help me out.
www.sendspace.com/file/d1vtq3
Thanking You sir...
Nithin
[QUOTE] Hi if you do time transient solving in "automatic time steps" the COMSOL sover is set up for diffusion type solvers, so it expects to be able to take larger and larger steps, ut if you introduce periodic BC conditions, the solver might step over a transition. Try the solver settings time stepping (far down in the solver tree) and use intermefdiate or strickt (check the doc) and be sure a few steps are on the transitions. Then use "smooth transitions, "step" funcions, and NOT Dirac steps -- Good luck Ivar [/QUOTE] Sir.. I have made the corrections suggested by you in the above comment. But still, the problem persists. I request you to have a look of the model in the link and help me out. http://www.sendspace.com/file/d1vtq3 Thanking You sir... Nithin
Posted: 10 years ago 18 set 2015, 06:42 GMT-4
Hi Nithin,
I am also getting same error. could you please help me out in this? How did you resolve your issue, Waiting for your help.
Bilal
Hi Nithin, I am also getting same error. could you please help me out in this? How did you resolve your issue, Waiting for your help. Thanks, Bilal
