Conductivity gradient error
Hello everyone,
I am working on a simulation in COMSOL to check how the electric current moves in the system where I model a box with three layers: insulator, conductor, and insulator. The layers have micrometer-scale thickness, and I am studying how current flows through the system.
I am using the Electric Currents physics interface in the Frequency Domain. However, when I assign a conductivity of 10^7 S/m or higher to the metal layer, the solver fails to converge. I have tried various solvers, but none of them successfully solved the problem.
After doing some changes, I found that COMSOL struggles with large conductivity gradients, which seems to be causing the issue. Interestingly, the simulation works fine if I reduce the conductivity to 10^1 or 10^2, use Stationary Study and also when I use a frequency higher than 1 MHz. However, for frequencies between 1 Hz and 1 MHz, the solver fails to converge.
I would really appreciate any guidance on how to address this issue. Has anyone encountered a similar problem?
Thank you in advance
1 Reply Last Post 14 feb 2025, 02:48 GMT-5
Posted: 1 week ago 14 feb 2025, 02:48 GMT-5
the ec physics needs a non-zero conductivity in all domains. I used 1 S/m in the air and plastic domains and it solves. 1e-15 S/m in plastic is too low for the solver. You can test how far you can go down if 1 S/m seems too high for your model. The mesh in the thin layers is probably not fine enough for an accurate result.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, the ec physics needs a non-zero conductivity in all domains. I used 1 S/m in the air and plastic domains and it solves. 1e-15 S/m in plastic is too low for the solver. You can test how far you can go down if 1 S/m seems too high for your model. The mesh in the thin layers is probably not fine enough for an accurate result. Cheers Edgar
Reply
