22 feb 2013, 07:26 GMT-5
are you sure you selected "3D" or "2D" when starting your model ?
22 feb 2013, 09:58 GMT-5
Yes, of course I'm sure I selected 3D . I don't understand why the program gives this error :(
When I changed the electrical circuit node's parameters (for example resistor, external I vs U. parameters (i.e p:3 n is empty) etc. ) this time program gives an another error such as "The DAE is structurally inconsistent. Variables:2 Equations:1 Error in automatic sequence generation"
I appreciate you can give me some suggestion
Regards
Asli
Regards
Asli
22 feb 2013, 13:16 GMT-5
it's rue CIRis 0D "physics" so it's therein, you need to have a logical circuit without tangling items, check again your id numers, and note these re different (not linked) to the Terminal number id's
24 feb 2013, 04:28 GMT-5
Hello Mr. Ivar,
What are the means of the terminal numbers and id numbers? Can you give me an example? I can not found the solution :(
My elecrical circuit (cir) parameters are:
Groung node 1: Connected to node 0
Voltage Source: p:1 n:0
External I Vs. U 1 : p:2 n:1
Resistor 1 : p:0 n:2
External I Vs. U 2 : p:3 n:0
Resistor 2: p:0 n:3
Hello Mr. Ivar,
Resistor 2: p:0 n:3
13 mag 2013, 06:57 GMT-4
I am having the exact same issue attempting to model an E-Core transformer. Has anyone found out what the problem was?
2 lug 2013, 13:14 GMT-4
Were you using the time domain, as in the example model? I was also having this problem, and I discovered that switching from frequency domain to time domain fixed it.
28 nov 2013, 09:10 GMT-5
Do you mean model in this site?
I had same problem.
First, I only solve with time dependent study.
It was solved. And then, I added coil calculation. It worked.
I had same problem.
8 years ago
7 apr 2016, 08:43 GMT-4
hello,I have the same problem,but I find the solution method .Maybe you circuit source is wrong ,and you can change it.
