How to plot required results??
Dear sir,
I wish to create an imaginary plane in required location of my model and plot the results like Maximum, Average and Minimum temperatures at that particular plane. How can I do that?
3 Replies Last Post 27 feb 2013, 01:50 GMT-5
Josh Thomas Certified Consultant
Posted: 1 decade ago 26 feb 2013, 11:21 GMT-5
1) Right-click on Results>Data Sets and select Cut Plane
2) In the Settings window, change Plane type to General
3) Define your plane that cuts through your geometry
4) Right-click on Results and select 2D Plot Group
5) Right-click on 2D Plot Group and select More Plots> Max/Min Surface
6) Right-click on Derived Values>Average>Surface Average
7) In the Settings window, change the Data set to Cut Plane 1
8) In the Expression field, select appropriate expression (ie T, p, etc) to find average
1) Right-click on Results>Data Sets and select Cut Plane 2) In the Settings window, change Plane type to General 3) Define your plane that cuts through your geometry 4) Right-click on Results and select 2D Plot Group 5) Right-click on 2D Plot Group and select More Plots> Max/Min Surface 6) Right-click on Derived Values>Average>Surface Average 7) In the Settings window, change the Data set to Cut Plane 1 8) In the Expression field, select appropriate expression (ie T, p, etc) to find average
Posted: 1 decade ago 26 feb 2013, 23:43 GMT-5
But sir, while following the method you have suggested, it is plotting the results with a range of 0-1 and a step of 0.1. But, the time step I require is in the range of 0-86100 with a step of 300. How can I change it to the required pattern??
[QUOTE] 1) Right-click on Results>Data Sets and select Cut Plane 2) In the Settings window, change Plane type to General 3) Define your plane that cuts through your geometry 4) Right-click on Results and select 2D Plot Group 5) Right-click on 2D Plot Group and select More Plots> Max/Min Surface 6) Right-click on Derived Values>Average>Surface Average 7) In the Settings window, change the Data set to Cut Plane 1 8) In the Expression field, select appropriate expression (ie T, p, etc) to find average [/QUOTE] But sir, while following the method you have suggested, it is plotting the results with a range of 0-1 and a step of 0.1. But, the time step I require is in the range of 0-86100 with a step of 300. How can I change it to the required pattern??
Posted: 1 decade ago 27 feb 2013, 01:50 GMT-5
By default the solver temporal range goes from range(0,0.1,1) (see the Study - Time dependent node), you can change that to:
range(0,300, 86400)
knowing that by default COMSOL is counting time in seconds (another way range(0,1/12,24)[h] )
Hi By default the solver temporal range goes from range(0,0.1,1) (see the Study - Time dependent node), you can change that to: range(0,300, 86400) knowing that by default COMSOL is counting time in seconds (another way range(0,1/12,24)[h] ) -- Good luck Ivar
