mesh generation
Hello, I encountered some technical issues while conducting simulation calculations using the electromagnetic module and would like to consult you. Currently, I am using the user-controlled mesh generation method. However, when the calculation reaches approximately 70%, the calculation speed significantly slows down, and the convergence curve becomes a horizontal straight line, failing to meet the convergence criteria. Due to the large scale of the model, if I were to switch to the physics-controlled mesh, it would result in an excessively high memory requirement, exceeding the capacity of the current computer configuration. I would like to ask if you have any suggestions for optimizing the mesh generation settings in this situation. Thank you very much for your guidance!
1 Reply Last Post 13 apr 2025, 18:48 GMT-4
Posted: 5 days ago 13 apr 2025, 18:48 GMT-4
For generic advice that may be relevant, see https://www.comsol.com/support/knowledgebase/1260 and https://www.comsol.com/support/knowledgebase/1030 .
If you can post your .mph file to the forum, you may be able to get more specific suggestions.
For generic advice that *may* be relevant, see https://www.comsol.com/support/knowledgebase/1260 and https://www.comsol.com/support/knowledgebase/1030 . If you can post your .mph file to the forum, you may be able to get more specific suggestions.
Reply
