Electromagnetic forces on parallel current-carrying wires - Comsol example
Dear all,
I suppose that Comsol example: Electromagnetic forces on parallel current-carrying wires in ACDC_Module/Verification_Models/parallel_wires should be fully and properly working example.
I tried to change currents in wires in Parameters section from 1A to 10, and 100 A and after that I observed that the calculated force was not changed.
Is something else I need to change? Am I doing some mistake?
Comsol version is 4.3.
Thank you in advance,
Jozef.
6 Replies Last Post 7 mar 2013, 17:25 GMT-5
Posted: 1 decade ago 7 mar 2013, 16:08 GMT-5
obviously yes something is not OK, as you should see the force increase ;) but normally, if set up corectly, the change in current it all was is required
Hi obviously yes something is not OK, as you should see the force increase ;) but normally, if set up corectly, the change in current it all was is required -- Good luck Ivar
Posted: 1 decade ago 7 mar 2013, 16:10 GMT-5
Jozef,
you must go to the node 'Derived Values' and re-evaluate both subnodes.
Then you see an increase of forces by a factor 100 after an increase of current by a factor of 10. That is how it should be.
Cheers
Edgar
Jozef, you must go to the node 'Derived Values' and re-evaluate both subnodes. Then you see an increase of forces by a factor 100 after an increase of current by a factor of 10. That is how it should be. Cheers Edgar
Posted: 1 decade ago 7 mar 2013, 16:17 GMT-5
Thank you Ivar, but I need more concrete answer. Jozef.
Posted: 1 decade ago 7 mar 2013, 16:32 GMT-5
Thank you Edgar, now it is working. Jozef.
Posted: 1 decade ago 7 mar 2013, 17:18 GMT-5
It's true that the derived variables nodes are not updated automatically, you need to do it manually ;)
Hi It's true that the derived variables nodes are not updated automatically, you need to do it manually ;) -- Good luck Ivar
Posted: 1 decade ago 7 mar 2013, 17:25 GMT-5
Thank you Ivar.
Jozef.
Thank you Ivar. Jozef.
