solver settings
I'm using two physics piezoelectric and moving mesh. I want to change the thickness of the PZT layer using moving mesh and want to calculate the voltage value for each thickness. how to do it in comsol 4.2a. I can do this in comsol 3.5a. Moving mesh is solved using stationary solver and PZT is solved using frequency solver. I used parametric segregated solver in 3.5a to compute the above said operations.
1 Reply Last Post 8 mar 2013, 02:52 GMT-5
Posted: 1 decade ago 8 mar 2013, 02:52 GMT-5
I would suggest to change the thickness of the domain via a parameter and a geometrical parametric sweep, else its rather the DG you should use , but in addition to ALE it becomes tricky
Hi I would suggest to change the thickness of the domain via a parameter and a geometrical parametric sweep, else its rather the DG you should use , but in addition to ALE it becomes tricky -- Good luck Ivar
