element quadrilateral quadratic 8 nodes
Hi!
How can i to do a mesh with element quadrilateral quadratic 8 nodes?
Thanks!
1 Reply Last Post 9 mar 2013, 04:29 GMT-5
Posted: 1 decade ago 9 mar 2013, 04:29 GMT-5
you mean blocks ? tra y mapped aud mesh on asurface, and then sweep the mesh in the other direction.
Note that sweep mesh is slightly tricky, and have some limiting requirements on the topology of the lateral (sweep length) sides, these have to be identical
This implies often that you need to cut up your geometry into many blocks, by adding internal boundaries
Hi you mean blocks ? tra y mapped aud mesh on asurface, and then sweep the mesh in the other direction. Note that sweep mesh is slightly tricky, and have some limiting requirements on the topology of the lateral (sweep length) sides, these have to be identical This implies often that you need to cut up your geometry into many blocks, by adding internal boundaries -- Good luck Ivar
