connecting solid and beam elements.
how can I use the beam element to act as a shear connector between two solid elements.
2 Replies Last Post 2 apr 2013, 05:29 GMT-4
Posted: 1 decade ago 13 mar 2013, 11:03 GMT-4
it's quite some knitting of the Dependent variables, as beam come in as lines onto the model and you need to apply the beam end node values to the full connecting boundary, also to link the angles from the beams, you can use rthe rigid connectors (this "makes the link 100% rigid though) or you can use weak constraints
Hi it's quite some knitting of the Dependent variables, as beam come in as lines onto the model and you need to apply the beam end node values to the full connecting boundary, also to link the angles from the beams, you can use rthe rigid connectors (this "makes the link 100% rigid though) or you can use weak constraints -- Good luck Ivar
Posted: 1 decade ago 2 apr 2013, 05:29 GMT-4
Thank you for your help
