Automatically parameter increasing
Dear friends,
I have a simple 2D rectangular model, I want to measure some acoustic properties in my desired frequency range, for specific height of model it's easy, but I want to check a range of heights for example 0.1 mm to 10 mm, with 0.1 increment, how can I set COMSOL to do this and save data automatically?
Regards
1 Reply Last Post 13 mar 2013, 13:46 GMT-4
Posted: 1 decade ago 13 mar 2013, 13:46 GMT-4
you have the Parametric Sweep node to get one or several Parameters running and have these parameter values defining your geoemtry shape diemnsions, then let it run ;)
Hi you have the Parametric Sweep node to get one or several Parameters running and have these parameter values defining your geoemtry shape diemnsions, then let it run ;) -- Good luck Ivar
