Transmission between the gratings
Hi,everyone:
I try the same way like calculating the transmission between different liquids, and the result is correct. But, when I use the same way to calcuate the transmission through the grating from the water, i find transmission pluses reflection ratio does not equal1. By the way, i have attached the mode for your preference. Thanks very much.
0 Replies Last Post 19 mar 2013, 05:18 GMT-4
Hello Pengjiang Wei
