Possible to export the streamline coordinates?
Hi, I am only using the laminar flow conditions,
I have plotted the streamline after the simulation, is there anyway to get the streamline coordinate from the simulation?
I like to export it if it is possible.
JC Hyun
5 Replies Last Post 29 giu 2015, 02:21 GMT-4
Hello JC Hyun
Posted: 1 decade ago 28 mag 2013, 11:33 GMT-4
Hi JC Hyun,
I have the some problem as you.
Did you solve it? How?
I would like to import one streamline in my geometry in order to do balance a through it and to refine meshes along it.
Could you help me?
Thanks a lot,
Francesca
Hi JC Hyun, I have the some problem as you. Did you solve it? How? I would like to import one streamline in my geometry in order to do balance a through it and to refine meshes along it. Could you help me? Thanks a lot, Francesca
Posted: 1 decade ago 29 mag 2013, 02:12 GMT-4
You can do this using export of plot data: Select the Streamline node and right-click. Choose "Add Plot Data to Export" from the context menu. Browse to some file and click on Export in the settings window's toolbar.
Posted: 1 decade ago 29 mag 2013, 03:48 GMT-4
Thanks a lot Gunnar!
I successfully did it.
Thanks a lot Gunnar! I successfully did it.
Posted: 10 years ago 26 giu 2015, 11:29 GMT-4
I exported data and got x, y, z coordinate with one more column for streamline which has whole integer number. Cold you please explain what is this streamline number about?
Posted: 10 years ago 29 giu 2015, 02:21 GMT-4
The streamline plot contains a set of streamlines. The integer is simply a streamline number. Without this number, you don't know what points belong to what streamlines.
[QUOTE] I exported data and got x, y, z coordinate with one more column for streamline which has whole integer number. Cold you please explain what is this streamline number about? [/QUOTE] The streamline plot contains a set of streamlines. The integer is simply a streamline number. Without this number, you don't know what points belong to what streamlines.
